Welcome Guest - Sign Up today
Store Links Mobile - Shop Now
SITE MAINTENANCE
The iBoats Forums will be down for maintenance starting at 10 AM MST on 12/16/2017. The estimated amount of downtime is 3 hours (we are expected to be back up at 1:00 PM MST). Thanks for being a part of the iBoats community!
See more
See less
fiberglassing the boat deck?
  • fiberglassing the boat deck?
    i have done alot of reading on this site and was wondering.... poeple on here said when putting a new deck on your boat you have to first fiber glass the edges. that part i understand now here is the question. they say next to put 2 thin layers on the deck to cover the wood. does it matter if it is 2 thin layers or one thick layer. im thinking thin is 1.5 ounce and thick would be 4 ounce . does 2 thin layers make a stronger deck than one thick layer.
    my boat
    http://forums.iboats.com/showthread.php?t=243841
    http://forums.iboats.com/showthread.php?t=308089
    Re: fiberglassing the boat deck?
    thick would be a 24oz.
    the glass it there to waterproof the deck and provide srtuctural stability.
    a csm (chopped strand matt) and a final layer of woven roving would be strong....
    you could use these in lighter qualities. below 7 oz
    The Hull Extension Thread
    great info on all aspects on boat building with detailed information.
    http://forums.iboats.com/showthread.php?t=234392
    IN MEMORY OF Our friend SpinnerBait_Nut LESTER WRIGHT July 31, 1953 - Nov 26, 2008 RIP
    IN MEMORY OF Our friend Tashasdaddy Robert (bob) Griffis. October 27, 1948
    November 29 2010 RIP
    • #3
      I'm going to be doing my deck with one layer of 8 oz, two layers if I get ambitious. I just happen to have a lot of 8 oz fabric.
      Erik
      Sea Ray SRV-210 - Winter refit
      75-85 foot displacement hull trawler - gleam in my eye
      • #4
        ok so it doesnt matter if it is done with one thick layer or 2 thin layers
        my boat
        • #5
          I used one layer of 1.5 mat, then one layer of 8 oz. cloth. I figured this should be strong enough.
          The mat is there for a good base for the cloth.
          sigpic
          2007 Chaparral 255 SSi, 496/375HP
          Rebuilt 1986 Chris Craft 178 BR
          • #6
            Yeah, I should mention that I use epoxy, so no mat needed.
            If you use poly resin, mat is a really good idea. Epoxy, one layer is fine.
            Regardless you're looking to build up enough of a surface of glass and resin to protect the deck from abrasion, waterproof it, and bond it to the rest of the boat if you haven't done that otherwise.
            Any way you do that is fine as long as it achieves all that.
            Erik
            • #7
              ok thanks for all the replys
              my boat
