Mark42
- Oct 8, 2003
- 9,334
Was thinking of a way to add heat to a small cabin with the hot water from an outboard motor. Figured that a simple auto heater core and small fan could be used. Run 3/4 water line from outboard block to heater core, then out from heater core to a through hull out the side. Add a valve to adjust the flow to keep pressure up on the motor.
I know the water temps will only be around 100 to 120 or so, a lot less than what comes off the block in a car. But 100 degree water will provide a few BTU's in a small cabin to take the chill off on a cold day.
Anyone do anything like this? Think there is any impact to cooling the outboard?
