Welcome Guest - Sign Up today
Store Links Mobile - Shop Now
No announcement yet.
leaky seam on tracker deck boat
  • leaky seam on tracker deck boat
    Hi, I have a 1999 Aluminum Tracker Party Deck 21, which is leaking along the bottom seam. Anyone recommend a good epoxy, or other solution for the problem?
    Re: leaky seam on tracker deck boat
    Here's the stuff you need: http://www.marinetex.com/PRODUCT%20P...0prod%20in.htm
    Life may not be the party we hoped for, but while we are here we might as well dance
    • #3
      i used a 3m marine epoxy in a caulk tube. forget the name but its a wite tube with purple 3m logo. it has been working great for 3 years now. wire wheeled the seam first, ran a bead down the seam and repainted. went from major leaking to dry as a bone.
      • #4
        The 3M product is: 3M-4200.
        If you can get to the seam from the back side (inside), use Gluv It.
        Both products are available, here on iboats.
        • #5
          Ayuh,.............. Gluv-it is a Tin Boater's Best Friend.................
