reelfishin
- Mar 19, 2007
- 3,043
I have to fix a small crack in a lapstrake aluminum hull, it's a small split about 3/8" long right at the corner or upper end of a rib. There is no deformation of the metal, just a small crack. I am debating on whether to just drill and epoxy this or to weld it. I am concerned that welding on the open sheet metal sides may warp the side panel?
Someone had tried to repair it with some sort of sealer but it looked like body filler or some sort of resin or epoxy. They didn't clean it so it didn't stick, and they made no attempt to access the inside area either.
I'll have the floor completely out and will be either epoxy coating or using Gluvit on the entire inside below the water line.
The dark areas in the pic around the damage is still some of what ever sealer they had on it, the rest of the area is rough from someone either trying to use heat, or from someone hammering the area to close up the crack.
Here's a pic:
Here's a pic:
