jddenham
- Aug 8, 2006
- 393
I just got a new project; a 1989 Bayliner Capri 17' with no motor.
The guy I bought it from had tried 2 different motors on it besides the original force 85.
He siliconed the top of the transom where the plastic trim had fallen off.
Luckily the boat hasn't seen much water, so the transom is dry and OK.
Here's where I need help:
I want to take the transom cap trim off, clean the silicone off, and seal the transom up with maybe some epoxy or polyester resin, or 3M 4200? Then I want to have a nice aluminum cap piece made.
My next dilemma is mounting my 1975 Mercury 150HP motor. I have a jack plate that I'd like to use since these merc's only have one set of mounting holes. This makes the steering tube not fit. Is there a way around that? Should I forget the jack plate?
Lastly, there are a couple of spots where the gelcoat is chipped and you can see the fibers, like the pic right above the drain plug. I know the easiest fix would be epoxy. Would the correct way be a gelcoat repair kit? I would like to keep the materials on the exterior consistent in case I decide to paint or re-gel the boat. There aren't but two or three such spots where a repair is necessary. Will water seep through spots like this where you can see the fibers?
As far as all the mounting holes go, I was going to fill them in with epoxy? I could then sand/grind it back and do the gel coat repair?
Thanks for reading this rambled post! Any help or thoughts would be appreciated.
