Re: DIY swim platform??
I built one this past week and tried it out for the first time yesterday at the lake. Performed beautifully. I took some photos, and will upload them soon. In the meantime, here's what I did:
To save a bit of money, I was going to build with Douglas Fir. However, Mahogany was cheaper - something about the market being flooded with Exotic woods right now. I forget the whole story from the lumber guy, but suffice to say, I went with the mahogany (S4S). I bought enough 1x6's and 1x4's to construct a 6'x22" platform, as well as #8 SS screws and Marine Goop to glue and screw. The screws were fastened from underneath the platform for aesthetics. Total cost? 100 bucks. The platform was built with 1/4" spacing to allow drainage as well as dissipating the "slap" of waves and ripples hitting from underneath. When finished, I sanded with 120 grit and then down to a final of 220. After considerable research, I settled on using Penofin Marine Finish. This is really a great product - goes on easy and requires only one coat. Not cheap (about 35 buck/quart), but I have enough leftover to do another 4 platforms!
For hardware, I had a hell of a time deciding what to do. In case you haven't noticed, supports are very expensive - about $85 apiece. They must be 24 kt gold filled. Anyway, I went to a local welder/metal fabricator and had them cut 4 lengths of SS 7/8 tubing which they flattened with a press at both ends. I then bent these in my vice to the required angles to match the transom and platform as well as drill two holes at each flattened end. I also had them cut me three pieces of aluminum L bracket to mount the leading edge of the platform onto the transom. The poles then project outward to the trailing edges of the platform. Total cost for the hardware - 70 dollars! The result is a structure that easily supports the weight of both my son and I. VERY strong indeed. All screws into the transom were sealed with 3M 5200. Screws were #12 for mounting the hardware.
Heed: Be prepared to toast a few drill bits on the tubes. If you decide to spend a few extra dollars on cobalt bits, it'll make the job easier. Slow and steady is the trick. It can be done with reg or titanium bits, but you'll burn a few up!
I've decided that it came out so nice that I'll likely begin making and selling them on EBay. It looks very similar to platforms you see on Tiges, Mastercrafts, etc.
