Making Fiberglass shine again
Status
Not open for further replies.
rndcomp
Any good ideas on how to bring back the luster and shine of an older fiberglass boat?
Thanks!
cnyman
Re: Making Fiberglass shine again
If it is gelcoat (and it most likely is) it can be wet sanded and polished back to a shine. A way to test is to get some Meguires Heavy Duty Oxidation Remover (from any marine supply store) and rub some on a spot. Push really hard and rub until all of the polish disappears. If the area is acceptably shiny, then a buffer and a lot of work will bring it back. The wet sanding just takes less time than trying to buff off all of the oxidation. Use 800 grit sandpaper and a rubber sanding block. Stay off of hard edges(the buffer will do these areas) and just use a bucket of water to keep the paper "cutting". Do the entire area with the sand paper then use the oxidation remover to buff out the scratches left by the sanding process. Good luck with your project.
brodie6
There are tons of methods used. Do a search and ye shall find. Me?
I used 3M Super Duty compound, 7" polisher, maguire cut pad. Excellent results. Brought back a 1986 heavily oxidised blue gelcoat to near showroom. Like I said there are alot of opinions on this READ ON!!
rndcomp
Thanks for all of the great suggestions. Is it normal to do only the the upper half of the boat (above the water line), or, do you the underside as well? If so, how do you work around the trailer rollers?
Thanks!
rndcomp
One more question, what about pin striping, some of mine is starting to come off. Is it better to remove it altogether. If so, what is the best way.
Thanks
Nova II 260
Heat gun and credit card scraper will remove stripes.
Big Keepers
I just compounded my MFG for the first time in probably its life. I bought some 3M Restorer and wax for fiberglass gelcoat hulls. I used my friend's variable speed Dewalt wheel. Set for 1200 rpm with a compounding pad on it, I used two large bottles to do the entire boat. I did everything from the waterline/bottom paint and up. The sides, the top everything. I even did the inside by hand with a rag. Then I waxed it with 3M Scotchguard. It looks 1,000 times better. Next season I'll hit up the tops again with another compounding. It will improve the shine even more. The sides I may let be for a while. They came out really nice.
reeldutch
hey big keepers,
are you all done at wilson tech?
Edko
Thanks
Rubber pinstripe wheel was recommended to me and I found the results extremely good.
cbavier
Thanks
Be aware if you remove the pinstriping you will have a shadow where the stripiing was and it WILL NOT EVER POLISH OUT same with any decals , stickers or A Boat Name. There will always be a shadow.
jserb
Why cant you get these out>? I have on the side of my hull where the letters were you can see the difference, Why cant you uselike an 800 grit here and then step it up to a 1000 in this area and then buff it out? I dont see why a good buffing wouldnt take it out anyway. You thoughts?
cbavier
Because when the boat is new and the decals are put on. The Fiberglass and Gel coat are new. Fiberglass fades and oxidizes from Sunlight and UV rays. When you sand or polish you actually remove some of the Gel Gloss/coat but you can never bring the fiberglass back to it's original state unless you take it all off and apply a new Gel coat. The shadow will always be there. I know some people think well it will age and fade with the sun and eventually blend in but that's not true because the parts where the stripes, Decals, Boat Letters, Boat Name, State Registration stickers were not, will also fade as well as the protected ares by the stickers. I have found the best process for restoration to be. Follow the manufactures instructions to the letter.
1- An acid wash to rid the fiberglass of oxidation is necessary.
2- If Oxidation is bad? You'll know it when you swipe your hand and you get oxidation on your hands or clothes. Use 3M Color/ Gloss restorer # 09089
3- If oxidation is light use 3M 09009 wait two days and then wax again.
4- If you use Use 3M Color/ Gloss restorer # 09089. After the boat sits for a couple days to harden. Then use a good Marine Wax before ever putting it in the water. Wax- Wax-Wax. Or you will be back in the same boat in a couple years. Pun Intended. A good rule is wax in the early Spring, Mid summer and late Summer. Then after twice a year Spring and Mid Summer.
I've tried different products and have found these to work the best. I don't have time or the energy to try products that don't work.
"Chuck's Fiberglass and Color Restore"
With all that said and I know I'll get some repraisals. I just know what works.
Use a Commercial Variable speed buffer starting slow and increasing your speed. The walmart waxer and Polisher won't last even half the boat.
The Deadliest thing to Fiberglass is UV rays. The wax protects the fiberglass from the UV Rays. The hardest thing on a Fiberglass boat is sitting on a boat hoist all summer because it not only gets the rays from the sun directly but it also gets it bouncing off the water. So the boats on a hoist get a double wammy. If I were to keep a boat on a hoist I would cover the boat all the way to the water with a tarp. Maybe using milk jugs filled with water and tied to the grommets of the tarp.
No I don't work for 3m
Now you have just had a brief lesson in Fiberglass care and repair. Oh the 3m
products probably can be bought at your local Marine Dealer but they are
not cheap. So the decision to remove stripes and decals are up to you. As far as the Shadow though. You will just have to live with it.
boat1010
When I got my boat it was a mess. I wet sanded it with 400 grit then again with 1000. Buffed it with a variable speed buffer and Maguires buffing compound diamond cut. then a good marine wax. Looks great now. And they sell a pinstripe remover tool. It is a air grinder with what it looks like is a bug eraser. Really slick takes the pinstripe right off.
Love Boating
where can I find Mequires products at Because I to am looking to bring back shine to my Boat, plus removing all stickers and decals maybe replacing with new decals if I can find them.
cbavier
Any Marine Dealer and some Auto parts store
boat1010
I got mine at a auto painting place.
cbavier
MeGuires just makes wax and cleaning suppplies. If you have oxidation you need more than MeGuires
Love Boating
Thanks for info sorry for spelling can anyone give me info on how to upload pics
Status
