Re: Respirator question
When fitting the mask, don't overtighten the cartridges or you'll deform the gaskets. Once the cartridges are in place, put the mask on and put your hands over the cartridges and try to breathe in. There should be no leakage. Then, cover the exhale valve and blow out. It should take some effort to break the seal of the mask on your face.
If either of those tests fail, adjust the mask. If you can't get it adjusted properly, you've got the wrong size mask. If you go with a full face mask, make sure your hair doesn't get between the mask and your face. The instructions will tell you the proper order to tighten the straps. Don't overtighten them. It won't affect the seal but it will make it uncomfortable.
Oh, and if you have facial hair you may not get a good seal so you may want to shave first.
