Re: Avenger Resto: STRINGER INSTALL; PLEASE L@@K!
Thanks for tip about the rounded edge, klos. Basically what you've described is a fillet, right?
I'm worried because I've never done it before. Questions I keep asking myself: When I pull the weights off the stringer, will it hold together? Will the bottom of the boat turn out straight? What I used to bond it was unthickened resin and two layers of 1708 cloth on the hull. I then took a resin/microsheres mixure at about the consitency of thin peanut butter and put that on the mating surface of the stringer. When I pushed it in place not as much of the resin/micropheres mixure squeezed out as I would have like to have seen. Well, tonight I'll pull the weight off the thing and see if it stays.
TG
