There are alot of fillers and puttys out there whether you buy them off the shelf or mix your own. I would like to see what the users of this forum use that they consider the strongest. Let's say... for gaps around new transoms before they are glassed in. I usually use poly resin with milled fiberglass for this and poly resin with cabosil for less structural applications. What do you think is the strongest?? T.
