I just completed a repair on the bottom edge of a 15' fiberglass boat that the previous owner had botched up pretty badly. The previous repair was entirely on the outside. I went inside and ground down a larger area, wiped it down good and and laid down four layers of heavy fiberglass cloth with epoxy resin. It's dry now and and looks and feels very strong. The previous outside repair was a "fiberglass patch" of sorts. It had high and low spots everywhere, really thin where the strength mattered most (it had actually cracked and was leaking water into the boat on the first trip to the lake). they had also globbed up a bunch of repair resin on the bottom really thick. I removed the patch with a grinder down to the gelcoat. I then took fiberglass stranded bondo and leveled the entire area out. It looks great now but here is my question.
Would it be a good idea to put a layer or two of epoxy resin over the repaired area on the outside to add strength/waterproof it? I have heard polyester resins soak up water and this repair is on the joint between the vertical and horizonal surfaces. I was thinking of two layers of brushed on epoxy (no cloth) then sand everything down prior to paint.
Does this sound feasable? Will the epoxy stick ok to the bondo? I'm experienced in aircraft and car repair but have never ventured into the marine world before now.
Thanks for your help,
SteveO
SteveO
