Welcome Guest - Sign Up today
Store Links Mobile - Shop Now
No announcement yet.
Soft spot in plywood floor and Smiths epoxy
  • Soft spot in plywood floor and Smiths epoxy
    I have a relatively small (maybe 5"x12") area that has gotten soft. I'm not crazy about ripping out the floor, the rest of it is fine. I hae done some research into Smith's Penetrating Epoxy, and it looks like a good option. Anyone ever use this producct?
    Re: Soft spot in plywood floor and Smiths epoxy
    Nope, but people do it with other epoxies (west systems, system 3, ect.).
    If it is really rotted though, I would overcutout the area (maybe 10"x20"). Make rabbet cuts with your router around the cutout of the existing deck. Cut a new piece of wood to the dimesions of the rabbet cut and then rabbet cut the new piece of wood. The rabbet cuts will form a lip for the new piece of wood to sit, increase the bonding area of new to old wood, and will prevent the new piece of wood from falling thru.
    • #3
      I have a similar situation with two smallish soft spots. However, I fully assume that when i cut a section out, I'll find waterlogged floatation foam under at least some of the floor. My guess is that most rot comes from trapped wetness under the floor.
      God luck - I hope it's as small an area as you think. I hope mine is also, but not counting on it.
      • #4
        95% of the time it comes from people not rebedding screws every couple of years or no bedding at all.
        I oversize drill every hole, fill with resin/cabosil, then screw whatever down. This way if water does get in, it doesn't hit the wood.
        • #5
          When you cut make sure that you cut out all of the bad wood even if the hole ends up being considerably bigger than what you thought. Rot is a fungus and will continue to travel unless completely removed.
          Back to Top
