Hello all. I noticed a crack on the top of my transom the other day and I started looking on the forum for information about whether my transom is in need of repair. I had also wondered why I was getting a brownish stain near my drain plug lately. I've looked at some repair options because I think it is probably in need of repair. The transom feels sound with no movement that I can feel. The boat is a 1995 Starcraft with a 90 HP Outboard. It's kept outside in the summer and in a barn in the winter. There always seems to be some moisture around the drain hole. I'm assuming it is moisture coming from the wood in the transom. Take a look at the pics and let me know how bad you think it is. Thanks!
The brown stain around the drain hole. The fiberglass appears to be chipped here.
The inside of the transom. I think it might be cracked a little bit...
The crack that started the investigation is on top of the transom just above the motor mount.
