Re: How do you flare a brass, through hull, bilge fitting?
Here is how I do it. First of all, I would not have used epoxy. My belief is that for this application it is too brittle. I use 3M5200. It is flexible, sticks to anything, and is very strong. I only say this because putting in and tightening drain plugs could over time break the bond between the epoxy and the brass sleeve. Then you would have it rotating in the hole, it could be a possible leak source, and could lead to transom rot. It just won't happen with 5200.
As far as flairing, the way I do it is to cut it 3/8th inches from the surface to be flared against. I use a 1/4 drive socket extension and a hammer, and I slowly tap the rounded socket end against the lip. I start on one side, then go across the circumference to the other side, and I alternate back and forth until I have worked my way around the sleeve and the edge is flaired against the hull. Usually because I used 5200, some will have squeezed out around the flair, which is fine.
I also brace the other end of the sleeve against the hull either with help or with a piece of wood or something. This way when I roll the edge on the other end it will be pulled even tighter. Once the 5200 cures it will never move again or leak.
The tool is the obvious better choice, but is impracticle unless you just like to buy tools or will be replacing a lot of drain plug sleeves. Good luck....
