Re: what is the best putty available
I have used marine tex on the bottom of the boat and it stayed where I put it.
This is from Marine tex:
Thank you for your interest in our Marine Tex products.
Marine Tex will adhere to old epoxy without any issues. Please make
sure
the area is scuff sanded and thoroughly cleaned.
I have attached an informative paragraph from our website that you may
find
very helpful.
How to apply gelcoat over epoxies (Marine Tex):
-Applying polyester resin (like gelcoat) over epoxy is very tricky and
must be done extremely carefully. The smaller the repair, the easier
it
is to coat epoxy with gelcoat. The larger the area, the polyester
will be
more difficult to work with and more likely to malfunction (not cure).
-Mix and apply the epoxy to the surface to be repaired. Be sure to
use
the correct proportions and keep the application at a minimum of 70?F.
-Let the epoxy cure for a minimum of 48 hours. Leave more time for
curing
if temperatures are between 68? - 60?F. (At least 72 - 96 hours.)
This
time for curing allows the amine blush (a waxy surfactant) to come to
the
surface.
-Clean the surface with a quick wipe of solvent. (please wash with
warm,
soapy water)
-Check to see if the blush is completely removed.
-Lightly sand with 120 grit sandpaper, clean again.
-You will now be ready to apply the gelcoat.
Please feel free to contact me directly if you have any additional
questions or comments.
Sincerely,
Kristy Redstreake
Rec. Marine Sales/Customer Service
ITW Philadelphia Resins
http://www.marinetex.com/
