New here Having transom replacement trouble
nickinfl
I bought a 1978 Mirrocraft aluminum that I'm completely redoing. The only problem I'm having is the transom replacement. There is a deck blocking most of my access to the interior bolts to get the wood off. Any suggestions?
GA_Boater
Welcome aboard, Nick.
Mirrocraft made a lot of different models over the years. Can you post some pictures?
After you make 3 posts, pics can be added in your 4th post. Look at the Forum Help in my sig and read about adding photos. Don't use Photobucket to host pics.
nickinfl
GA Boater,
​ Thanks I'm getting my posts up so I can post pictures. It looks to be the same as the rear of the boat in your picture.
nickinfl
What is this piece?
Does anyone know the name of the piece that comes from the transom and goes about 2 feet into the boat?
roffey
The captain, lol. sorry.
Not sure, I suspect it depends on what kind, make and type.
alldodge
Need a bit more info, there are several things that come to mind that extend into the boat from the transom. Is it bigger then a bed box, skinny, black, white, purple, plastic, rubber???
Got a pic?
robert graham
Without a photo, probably a transom brace....takes the force exerted on the transom by the motor.....my Jon boat has 2 of these braces welded in place
nickinfl
No Title
Sorry for the vague question. 1978 Mirrocraft MR Musky.
nickinfl
How to replace transom?
1978 Mirrocraft Mr Musky. I picked this boat up cheap and have almost everything stripped down. I have a problem with removing the transom. I cant access it from the inside of the boat. Any suggestions?
Woodonglass
You have to remove the splashwell by unbolting unriveting or grinding off welds. It's the only way. Don't worry...what ever comes off can be put back on just be as carefull as possible when removing the fasteners
GA_Boater
Nick - I combines your three topics because you are getting advice in all three, which is too confusing.
In you later pics, it looks like it's time to yank the transom wood straight up sand out. Didn't see any hardware still attached that would stop lifting the wood out.
The splashwell does not need to be removed unless you feel like it. Just make all the screws/bolts through the wood are removed. It is possible the ends of the gunnels need to be bent back for the wood to clear can't tell from your pics.
nickinfl
GA Boater, There are still bolts going through the transom that I have no access to because the splashwell is in the way. It seems ridiculous to have to remove the entire splashwell to change the transom.
nickinfl
No Title
The ones circled. No access from the inside without removing splashwell
GA_Boater
Are the 2 circled some of the ones you can't get out? What is the panel looking thing marked with the X?
nickinfl
The circled are the ones I can't get out. Two on the other side of the x thing. It's at the bottom of the splash well. I think I might be able to remove then replace it relatively easy.
GA_Boater
Those bolts are for the outer knee braces. Is the panel part of box under the splashwell? You shouldn't have to remove the splashwell if the panel/box can be removed. Our boats are almost identical, except I have no panel or box. Can you back up and take another picture showing the entire inside aft end?
