So I need to pull my belly tank, is it easier/necessary to take the hardtop off to remove ? It sways back and forth in heavy seas.. I think it's screwed into rotten wood.
To fix the transom and rear half of the stringers surrounding tank, where would you guys cut?
I've read to leave corners and around 6" to tab back onto...
Where would you guys cut !?
Boat is a 90 Proline 250 WA.
Also my boat deck is at Waterline along with drains .
Should I raise the new deck height or reroute to bilge and plug scuppers. Boat stays on trailer and used weekends.
how many inches freeboard is needed for legal charter boat use.
Lastly if I cut up the deck and the stringers are rotten under the cuddy cabin, then what !
