ok got all wood removed from transom it appears than the bottom of the transom is not level like they poured resin around it how do i attach ny new broads to the sides thanks
I'd recommend you spend some time in our restoration section. There's a number of great fiberglass boat restores going on that you could learn a ton from. Might want to have your thread moved there also (just PM a moderator or even just flag your own post and ask it to be moved) as you won't get much help down here in the Hurricane section.
