sergiophil
- Jul 11, 2015
- 54
Okay folks, going over my boat while I'm rebuilding the floor, I noticed a spot on my run rail that has some stress or spider cracks. This an easy fix?
I've done research seems that you grind down a little then get a gel coat repair kit? Any certain kit or can I use the gel coat I'm getting to put on my floor? I have a spot on bottom of my hull that I have to repair to, which I assume be the same process? Sand the area down, fill in with gel coat, then sand, polish, wax?
I'll get some pictures next couple days.
Any info greatly appreciated.
