I have a fiberglass Sea Pro boat that was given to me with substantial barnacle growth on the hull below the waterline. I've scraped all the barnacles off and used a 80 grit sandpaper to remove all signs of fouling. The hull is in very good shape and the sanding is only to the gelcoat on a fiberglass hull. The boat will not be stored in the water but trailered for launching. I am located in saltwater as well as brackish inlets. Do I have to paint the hull? Is it adviseable? Is there a coat I can use other than paint to restore the finish if the fouling likely wouldn't be too bad if the boat isn't stored in water? Thanks for the help in advance.
