Will post pictures tomorrow
1983 16 feet canoe with like 5 stringers, so one of the stringers were badly cracked and i decided to cut off to replace it and there was barely any wood left inside only dark dirt and empty space. I only cut off the top of it and lt was left with the same molding it had in it, so i cut off a piece of wood, place it inside of it and added a layer of fiberglass in 3 pieces followed by some nicer thicker fiberglass layer. today after 3 days i started washing the inside and the stringer got full of water inside of it and it leaks right back out through it. obviously, i don't know much about fiberglassing but i wonder what its wrong, i thought water was not supposed to filter through the resin or the resin i used is bad quality and didn't seal correctly ?
i know the inside of the stringer is not completely tight on the inside and there's an air bubble in it when i lay the fiber and it doesn't look nice either but i look forward to fix this leak problem
