savetexomabeaches
- Jul 4, 2013
- 420
The old power pilot -- shift, then throttle lol - Those remind me of using a lawn mower's throttle control
RCNelson You seem to be getting a lot more interest and feedback on your posts than I've gotten on mine. What is your secret to getting people to answer questions and give tips and feedback? Keep up the good work. BTW - What are they talking about when they refer to taking the cap off? Your boat doesn't look like it has a cap like some of the speed boats I've seen people working on where they take the top off. I'm not even sure if it's possible to take the top off the front of my 1974 Sea Ray 220. If it is, then I'd be interested in considering it. Keep up the good work.
Before you do so, did you brace it in all the right spots?
And... Take a LOT of measurements so you can ensure when you replace the stringers and deck it's all the same as it was before.
Also instead of removing the entire thing and tossing it somewhere, have you thought about just sliding it forward?
With a rotted transom, you most likely will just rip the U hooks out of the boat if you try to support it that way
When you start cutting and removing stuff, especially the cap, the boat is going to want to "stretch" out at the top on the sides. You'll want to measure how wide it is with the cap on and try to brace the sides so when you put new in and fiberglass it, it will be in the right position.
Here's a good thread for ya to look over -- http://forums.iboats.com/forum/boat-...-pics?t=234392
