No Title
Did a little research on the Seville series. Seems it was a trim package (think cars) that was a popular equipment group. It offered things like a convertible top, cooler and a few other standard goodies. Appears Seville was Sea Ray's move to a cost-effective product so they wouldn't loose market share to cheaper brands. Turns out the boat I have was available in 2 styles, cuddy and bowrider. It is marketed as their 5.6M series (for meters) around the planet. I finished the starboard side of the hull and was pleased it matched the port side after about a week of time off. Here's some things I've found:
1. The original cleats were flat-top with open base and were likely made by Schaefer, a high-end supplier. Problem is, the have a non-standard hole spacing of 2.0 inches (51mm). No aftermarket parts readily available. Schaefer sells 2.0 inch for a high price. They are chrome over bronze probably like mine which are only slightly pitted. Probably keep them.
2. The guy trying to sell the 2 Seville hull emblems for about $100 made me order regular 13 inch sea ray adhesive emblems for 1/3 the price. They fit great and seal up the 3 mounting holes for the cheap plastic Seville emblem. The height is bigger on the new emblems so it needs to be heated slightly and formed over the hull seam. Its a very small angle and the horizontal bend and it looks fine. I'll take pics later.
3. Wetness in the flooring below the starboard side jump seat next to the motor. Only about 8 inches long by 5 inches wide. Fiberglass had worn through because of the weight of the factory supplied cooler rubbing the flooring over the years. Stringer is probably OK but am doing water extracting then resin injection. Not enough other mess in this area to justify stringer replacement...yet. Side and back board of cooler in bad shape, will replace. Not impressed with factory material...reminds me of coarse particle board. Pretty sure its original.
4. Removing a very heavy ski ladder & platform off the back. I'll save it for the next owner if they want it. Seems like a lot of extra weight. Original steps were replaced with a longer bi-fold ladder. Platform and ladder in OK shape, ready to re-use someday.
p.s. Am retired engineer and love to restore things such as this "old" boat. I tend to get geeky on descriptions and materials, so bear with me. I am doing this for fun. Next Spring, I'll splash this beast in Lake Erie and make sure it passes my shakedown tests. After that, I'll sell it and pick out another one. Crazy? Yep...
