I have decided to start another project since im getting close to being finished with my first boat. I have an 1978 arrow glass 14 foot flat bottom boat that I am wanting to convert into a bass boat. I mostly want to convert it because when you move or drop anything in the boat it makes alot of noise. I also really like what others have done with their flat bottom boats by doing a conversion and adding organization to the boat with storage spaces, rod holders, find finders and more. I have a few ideas of how i would like to do it but figured some of you could give me much needed info on this project. I cant really find anything about this boat but I also haven't really looked all that hard for it. I have had this boat about 2 years now. I replaced rivets that were leaking and used 5200 when putting them in. I had some left over gluvit I put on the outside bottom of the boat over the rivets to do 2 things. First to test the gluvit. I know many don't use it on the bottom of their boats and gluvit is not uv resistant. Well I can say very surprisingly gluvit is some of the best stuff I have ever found for sealing stuff. In 2 years not a single leak and it is still in great shape and hard as a rock. Second reason i did it was to just add more seal to the rivets in case I screwed up somehow with a rivet or the 5200. Now for a few questions.
The main question is going to be about weight. Anyone know about this boat and its weight limits? I am leaving the foam in the benches and will be adding flooring with foam also. Do you think this boat will still be buoyant enough? I will likely only be using a trolling motor on this boat but I do have a 7.5 hp motor I might look into fixing up for this boat.
Second question how to go about mounting the decks and framing in the boat. How would I go through the hull and into the wooden frame or should I do an aluminum frame? Ive never cut or worked with aluminum before and I have no welder nor welding experience so remember that if you were going to recommend that.
The last question is can any of you give good recommendations on how the boat should be layout, what to add, where to add it. Things like storage spaces, rod holders the storage kind and ones that hold casted rods, fish finder, live well if you think there is room, lights for running trotlines and to light up the inside of the boat a bit and any other useful thing for fishing. I'm not looking for stuff like a radio or grill or anything like that. Just the usual needed fishing stuff. I fish for bass, sunfish, crappie, bowfin, catfish.
The boat is used on calm small lakes (up to 250 acre lakes) and small rivers and creeks. Here are some pictures of the boat and tomorrow I will post a design of a general idea of how I am thinking of doing the layout. Anything you guys can tell me about doing this project will be helpful.
