Hello everyone!
Just started a repair / restoration of an aluminum boat that was my great grand fathers. Completely gutted the thing yesterday and today, rinsed, brushed , and vacuumed out the hull to assess damage and hull viability. Overall I think the hull looks great save some surface corrosion on the inside and some serious stuff on the stern hull / transom. Everything is riveted together and from what I've read so far, I think a repair is well within my capabilities with some learning. The edge of the transom looks to be solid and the rest of the hull that isn't directly beneath the transom tresses looks good so that's what I'm aiming to replace. See attached imgur album for a better look at the problems and my proposed cuts: http://imgur.com/a/tvbY5
The only change I might make is pulling the cut in the hull to before the rib to remove the need to replace that. The rest of the transom will undergo a full rebuild as well, new plywood and support structures ( If the current structures aren't in as good a shape as they seem ). My first goal is to get this boat sea worthy / running again before tackling the rest of the rebuild. This boat will be salt / fresh water, as something to keep in mind. As a side note, if anyone knows of a company that does soda blasting in/around the Northshore of MA, I would love to hear about it!
