Hello,
I am having a few issues working out the best course of action to fix an 8 inch crack in the keel seam of my 1994 Tracker Pro V Deep 17. When we left the water this past Sunday we had a good amount of water pouring out of it. I would like to make sure the leak is fixed.
I contacted Tracker boats and they notified me that there is PVC tape between the aluminum keel seam and the hull of the boat. From what I have gathered from similar issues this can cause it to be very hard to weld the crack. The heat will cause the PVC to start fire or melt.
I contacted a trusted marine mechanic and told him the issue. He suggested using Marine Tex to fill the crack. However, I am skeptical that this will be the best fix for the issue. I have no experience with Marine Tex or no knowledge if it will fix the issue.
I was hoping someone could give me a suggestion on whether or not this crack needs to be welded, or if I can use Marine Tex to fix?
The last resort could also be replacing the whole keel seam. If I could order the part from Tracker would this be a big project to undertake? I have contacts who can rivet. I am just not sure about the PVC tape and other items that may go into this repair.
I have attached a few photos. The first is the location of the crack. It is located at the end of the red handled rake. The next photos are the crack up close.
If there is anything else I could post to help, let me know.
Thanks for your help.
