Hello All:
Just joined tonight. Lots of good info here.
I am working on an 18' Privateer I just boat. Took out the center console and bench and want to build a custom side console. I have done glass work several times but I do not know anything about the glass itself.
The ceiling is fairly new(glass over wood) and is solid. I want to build the console, glass it and glass it in place tying it into the ceiling, cooler board and washboard.
I was going to build it out of rigid foam and glass it in place.
Now for the questions...
Any suggestions for tying it all in together? I know there is a lot of stress where these points all come together. Should I do something different than just cutting away the existing glass where the new console will go such as cut it out and then cut finger joints back to kind of tie the new glass in to the finger joints for better mechanical hold?
Please tell me what type of mat, weight resin to use. How many layers? Inside as well?
I want the console to be super smooth like the hull when complete. Should I use resin with microblooms as a smoothing compound once I am finished with the matting?
That is all for now. I am sure your answers will spark more things on my end I have not thought about.
I appreciate everyone's time.
