ShoestringMariner
- Apr 18, 2015
- 1,563
Hey all, I just dragged home a 12' Springbok. It ain't pretty and needs some work. I have a few questions if I might ask;
1) there is a fast leak coming up from the keel at the front where the bow is pulled together and the keel is exposed. The PO sealed the outer edge of the keel with urethane so I am thinking the water is coming up from the weep hole at the rear of the keel...with these boats, was/is there typically some sort of rubber seal in the keel where it is exposed at the bow? It's a big gob of DIY special there now
2) this is a shallow boat (15" transom) and seems quite tippy. It has no rating or capacity tag...can I assume it's 2 adults max?
3) will 7.5 horse be too much?
4) should I put my battery and gas up front when it is just me? Feels like it sits high at the front without actually going anywhere.
Thanks in advance
Thanks in advance
