I have acquired this boat from friend and I'm stripping it down and repainting/sealing it. I have hit a spot where the rivets have ripped away and looks like they filled it with concrete. I need advice on how to repair this portion.
If the dark spot in this pic (next to the old rivet) is a hull breech then you will need to do as Gonefishin said and make a patch first to seal the hull.
So long as the damage is just in the keel strip/strake then you could repair both spots by removing material (red area in pic) around where the old rivets are (much like it already is in the 1st pic) to allow clearance for a rivet head to lay flush so you can seal the original hole. Then reattach the strip/strake to the hull on both sides with new rivets (blue circles).
Plugging the original holes and reattaching the strip/strake can be done with either the SS screw and nut method, closed end blind rivets, or solid rivets. I would recommend doing so with solid rivets or the screw/nut method as I think they would be the easiest on bare feet if they get stepped on.
I cut away where it the drawing says to today and cleaned the rest of the material out. The black spot was not a hole just some junk that had fallen on it. I'm going to try the closed end blind rivets. How do I figure out the size needed? This will be my first riveting project.
Thank you for all the help so far.
Daniel
