I am rebuilding a Bayliner Capri.
Floor is removed, streamers are removed. I'm down to the hull and now it's time to rebuild.
Can i get away with using a higher quality Home Depot plywood if I coat it in resin? I found a place in Portland that sells "Marine-grade plywood and they want $140 per sheet 4x8. Keep in mind, after the boat is rebuilt, I'm taking it to a shop and they are going to spray Line-X bedliner in the whole thing... I just dont' see how water would ever be in contact with the wood.
Thoughts?
Thoughts?
