I have a flanged brass tube that is solid, but it has been in the boat for over 40 years (all fresh water) and there is no sealant visible around the outside flange. It would be difficult to remove and replace the tube because it has an inner transom board in front of it. Could I get a seal from a bead of 5200 around the outer flange without removal? Or, is it possible to install a garboard plug over the top of the brass tube without removing it?
