DOZERII
You hit the nail on the head,I thought about it and looked at it ...its only a few rivets and I can Beef up the top end too.
thanks for the input. I guess closed end alum rivets and 5200?????????any other options?
E Z Off oven cleaner works great for cleaning aluminum
OK on the solids Dozer,I just never set any.
Did you read warnings on the label?
DO NOT use oven cleaner to clean aluminum!
Yes I have ... Can EASY-OFF? Heavy Duty Oven Cleaner be used on any aluminum?
We do not recommend using this product on aluminum, as it may pit and discolor it. However, it does not penetrate into the metal or remain on the surface after the recommended rinsing instructions have been followed. Utensils and appliances cleaned with EASY-OFF? Heavy Duty Oven Cleaner are completely safe for use in cooking or serving food after they have been thoroughly washed and rinsed in a vinegar and water solution.
so as long as you dont leave on for hours i dont see a huge problem. I used it to clean off my aluminum fuel tank on the outside with no problems...scrub it down and rinse it off.
