utfyrfytr, the hardener actually makes it a crystalized paint, not an epoxy paint. Most automotive paints are catalyzed paints that use hardeners. And since they are usually polyurethane paints, it makes for not only a very durable finish that resists scratches and marks, but also a finish that is impervious to oils, fuels, and so many other chemicals. So use the hardener and just make sure you clean the spray gun or whatever you use after finished. Otherwise, it will be useless to ever use again. And don't put any left over mixed paint back into the original paint can with un-catalyzed paints. It all will then be useless if you do that.
One other very important things to do as well. And that is use a 3M respirator (6700 series or eq.) or any other quality brand respirator when spraying such catalyzed paints. That stuff is dangerous to breath into your lungs. JMHO!
