Iboats is not cooperating with my iPhone to load pics. Seems ironic! Anyway, the only picture that would load is the one up. I will try a different route later. The original design had the motor mounted on an assembly with a rubber boot around it that had the motor extend through the hull itself. As this assembly and boot is nowhere to be found any longer I am needing to design, build and install a bracket and or transom as the old "transom" such as it is...is about 1/4" of fiberglass ONLY (no wood encased inside, no metal, no bracket, nothing else). It sounds like I may be the first to be blessed with this challenge??? Just for reference boat is former racing mini-hydro from early 70's and about nine feet long. Just putting a period correct 15hp outboard on it for puttering around instead of the 35hp racing motor.
