Hello,
I just bought a new boat here 's the photo.
It's made from wood covered with 6 a layer of fiberglass .
The Paint type 's gel coat .
I want to start to add a new look, i was thinking to spray the black Hull with gel coat metal flake, or change the black color to white color. Any suggest!
i have Gelcoat Equipment (Da sander - spray gun (HVLP) 1.8 ,1.4 .1.2mm nozzle etc... )
Also The seller give me ( 80 K.g of clear gel coat and 40 k.g of PVA and hardener, pigment black , white, red...etc ) :happy:
I have a little idea about spray gelcoat supposed to be followed: correct me if I'm wrong!
1- sanding all the Hull with DA sander 80 or 120 grit
2-MEK with a cloth wiped and clean it's so good
3-Use a 1.8 nozzle for first two coats providing buildup
4-Final coat with a 1.2 nozzle and at a higher ratio of thinning (8% styrene thinning to gelcoat by vol)
5-Spraying PVA over gelcoat ( i waiting 24h before spraying PVA)
6- Wash the hull with water and soap (after 48h)
*There some Changes in the steps if i use metal flake:correct me if I'm wrong!
3-Use a 1.8 nozzle for first two coats providing buildup (with color i choose)
4-Mixing the clear gelcoat with metal flake as well
5-Use a1.4 nozzle for spraying the clear gelcoat it's mixing with metal flake
6- After 24h Use 1.2 nozzle for final coat it's clear gecloat
7-Spraying PVA over gelcoat ( i waiting 24h before spraying PVA)
8-Wash the hull with water and soap (after 48h)
Thanks for every one taking the time to answer my questions and help me out
