I went out to check on the boat after the glass work dried over night. Man did we ever put the epoxy down thick. The areas that I feared last night were too thin I now see are what the finished product should look like. The areas I thought were good are thick with epoxy and smooth...no glass texture.
So, expensive lesson learned, to a point. My question is: how were were supposed to put the epoxy down the right way? Were tried a foam roller, and even though we had epoxied the plywood first, we seemed to just keep lifting the glass. I tried the metal West System roller and while it would help roll out bubbles, it didn't spread the epoxy. We ended up using a brush and our gloved hands. We got the glass pretty smooth, but again, way too much epoxy. I am assuming that we didn't hurt anything by using too much other than the budget, but I would certainly like to know how to do this correctly. I am going to go out tonight to sand the work we did last night and will add some strips of glass along the edge as you all advised. I am considering putting one more layer of 6oz glass down since I already have it cut to size.
Thoughts?
